With the mast down and compression post out in order to replace a bulkhead and compression block I found the flat 4 wire trailer stuff leading from the mast step, down inside the post, and through the bilge to the panel. I bought some good 4 wire from WM to replace the flat, and wonder if there's a reason not to take the wire across the top of the bulkhead on the head side, down the run by the hull deck joint and then into the panel? Seems like a better deal to keep wire out of the bilge. Any help?
