C22 slide out galley
Tony Borum
I have a stove/sink slide out and have never used it. It appears to be in very good condition. Does it take alcohol? Is it safe?
Bayard Gross
It probably does use alcohol
My original C-22 stove uses alcohol. I now use a Kenyon gas stove. The stove is safe per se, but can be tricky to get ingnited as sometimes a lot of alcohol ends up just below the burners and can make a lot of flame when first lighted. Might be best to try lighting it for the first time outside the boat. It should screw off the gally. I do not like the evaporation character of alcohol, that is the alcohol in the stove tank can evaporate if the seals are not perfect. However, the fuel is readily available and cheap enough.
john renfro
galley
hello tony, what brand and model is the stove? john
Dana
Maybe a new,camping stove
If there is any trouble with it,put in a LP camping job? They make some nice ones now!
