C 22 Low Spot
Randy: When at rest in my 1975 C 22, if there is any water in the bilge from any source it tends to end up in the battery area. When I had a problem like yours in my boat, I finally found the problem as far forward as you can go in the bow where the deck meets the hull. Water entered when crashing thru waves. The forestay tension had caused the separation. The fix was to install a turnbuckle between the forestay attachment bolt that goes thru the deck, and the bolts that attach the boweye that we use to attach to the front of the trailer, plus some sealant. Catalina Direct sells a nice kit for this repair, which is a common upgrade for older 22's. Dick
