C120 Chartplotter
May 10, 2014
5
Hunter 2005 41' Gig Harbor
I have a 2005 Hunter 41 ac. My master plotter is an E 80 at the desk below and E120 in the cockpit. The E80 , the master, is running perfect; but the E120 will not recognize the master. I updated the software and checked the cable in the back of the 120 but the 120 continues to reboot. The 120 will not even shut off properly when the E 80 is on, but will when the E80 is turned off. Has this happened to anyone?
thanks
Dave
Mar 23, 2013
132
Hunter 44DS Lake Macquarie
Hi, on my set up the e120 is the master and the one down below is set up as the slave
Jun 11, 2011
1,243
Hunter 41 Lewes
I have a 2005 Hunter 41 ac. My master plotter is an E 80 at the desk below and E120 in the cockpit. The E80 , the master, is running perfect; but the E120 will not recognize the master. I updated the software and checked the cable in the back of the 120 but the 120 continues to reboot. The 120 will not even shut off properly when the E 80 is on, but will when the E80 is turned off. Has this happened to anyone? thanks Dave
I have the same setup. I once had to go in and reset the 120 to look for a master. I think I had to do it with the 80 off and then turn them on together.
