I am a new owner of a C&C 34 1978 Vintage.
I am trying to seal and fibre glass the keel joint .The boat has a bit of the C&C smile in the the forward section of keel, extends about 1.5 ft back from leading edge.
Before sealing I would like to check keel bolt tension and was wondering if there is a recommended torque for bolt nuts.
Currently appears to be greater than 90 ft.lbs.
Does this sound right.All bolts were tight with no movement apparent.
Previous owner stated keel was repaired professionally a few years back.
Any comments and advice appreciated.
Bob
Bob
