Hello,
Been lurking this forum since last night and it seems full of great advice from helpful people
My dad just bought this boat and I'm the fixxer, I have plumbed a house from the foundation up but this will be my first marine project. I've been reading up in this, and the C&C forum and have a general plan.
The boat is a C&C 30 MKI and was sold with this (head plumbing) project started but the seller neglected to mention it.:cry: As it sits the head itself is a W-C Headmate 1460 and seems in good shape. The through hull fittings seem to have been recently done as they look new.
Here is a pic of what appears to be the discharge fitting with either the intake fitting or the sink drain under it: (Taken looking into the bottom cupboard under the head sink)
So you can also see the new hose and old hose that came with the project. There is another through hull fitting thats also brass just below the frame of this picture, you can see the tip of the plug in the picture. So question one: Which fitting is for intake and which is for sink drain?
I found this pretty useful page on westmarines site that outlines the type of system I want to build, here is the info "borrowed" from their site:
However the first and most glaring difference between this diagram and the boat is the waste tank. The tank on the boat is hidden behind the back wall of the head, and the pump out tube comes into the tank form the top and drops down to about 1" - 2" off the bottom of the tank, kinda like a straw into a cup. Question two: Can I still build the diagrammed system above with this type of tank? The tank also has a circular access port, waste deposit line and vent line all on top. Here is a pic showing the top of the tank:
(sorry about the junk in the picture,
I have a macerator pump but forgot to record the details before returning home last night, in this last pic you can also notice the three way valve graciously left from the PO. I'm sure i'll have a few more Q's as I start this project!
Thanks for taking the time to read & comment, sorry if I left out something obvious as I'm still learning about sailboats!
-Merrick
-Merrick
