C&C 30' MK II - Do you have a cage over the forward halyards on your mast head?
May 27, 2014
14
C&C 30' MkII Glenville
Trying a different approach
Is anyone still using the masthead cage over the front halyards, after changing their halyards from wire/rope to Dyneema?
Apex
Jun 19, 2013
1,212
C&C 30 Elk Rapids
I;ll have pictures of my arrangement after 29th (haulout) cage is there, as is 10mm halyard. No jamming issues
May 27, 2014
14
Are you routing your halyards thru the cage? Did you have jamming issues with halyards as the were pulled down between the outer cage rails and the forestay clevis pin?
Thanks in advance,
Apex
Jun 19, 2013
1,212
C&C 30 Elk Rapids
yes through the cage, no issues with jib or spin halyards.
May 27, 2014
14
So we are using the same size line and my front halyards are binding at the cage/forestay clevis pin junction and yours are not....
I will assume your front halyards are near the forestay.
What is the difference?? A picture of yours may be the answer. When your mast comes down.
Enjoy the rest of the season
