Some of the assumptions & data is either old
or not totally valid. I could see a few concerns you might have, but many are unwarranted.Not saying it doesn't happen but leaking hull to deck joints has never come up as a big concern for the C36. I have over 20 years of Tech Notes written by owners about issues they have had with their boat (BTW this is available to anyone on a CD from the C36IA if you want) and I can't say as I've ever had someone really complain. Your concern about water leaking into the core because of a minor docking incident (or any other reason) is totally unwarranted. I can guarantee that. One of the upsides of the Catalina 36 is that its hull is solid fiberglass there is no "core" to saturate.Just curious, do you know of anyone that has a C36 and has had an issue with their hull to deck joint leaking? Please have them contact me as I have would like to learn more about it, I've just never had anyone approach the Association with that problem. Now if you talk about leaking hatches and port holes, that is something I have heard over the years, but these are not hard to fix and something I consider part of boat ownership. (Just as an FYI Catalina does have a few boats like the Catalina Morgan Deck Salon 440 that is built with the "internal flange" hull to deck design, but I feel that is more appropriate for those bigger heavier boats)As far as a perforated metal toe rail, I like them too, I had one on my old Watkins 27. The reason I like them is more for utility and having a place to attach things to if need be. There are a few Catalina's that have steel toe rails (C440?). The big down side is how uncomfortable they are sitting on the toe rail with your legs hanging over the side. As far as the "bumper" around the transom, well I guess one could do that. I know many Hunters have that and I believe the new C309 has it. I guess they could do that with any boat that has a reversed transom, but personally, I think it ruins the lines of the hull. I don't know if you know this, but I believe many boats that do have the "bumper" around the transom is where the Hull To Deck joint is on the sterns of those boats. I really don't think you need to worry about the structural integrity of the hull to deck joint . Not saying it'll survive a collision with an ocean liner, but I have pictures of C36's that were ravaged at their docks from hurricanes and in many cases the hull to deck joint was not the worst part of the boat.The person that wrote that article misled you by implying all or most C36's decks are cored with plywood. They are not. Catalina has changed the material over time and in the 80's marine plywood was considered more than acceptable. (Many top named builders used it at the time). Catalina switched over to special cut end-grain balsa for coring their decks a long time ago. Many marine architects even consider it superior to foam and I agree. While both plastic foam and cut end-grain balsa eliminate wicking in the case of water incursion, the foam lacks the "Vertical" structural integrity that the balsa has in spades. Many foam cored decks will get "sponge spots" where the foam "collapses" over time, while the balsa is very sturdy in the vertical axis. Check a boat with foam cored decks after 20 years and check most balsa wood cored decks.I totally understand your comments on the winches being in front of the steering wheel, but it seems a lot of boats are like that. I have learned to manage that by sitting on the coaming with one hand on the helm and winch from there. I even brought that very same comment on the winch placement to Gerry Douglas, the chief designer at Catalina and his comment was that he understood, but immediately added "why don't you add an extra set of winches placed back where you'd like them". I must admit, I never really though of that. Then he went on to tell me that is exactly what he did on his C42 (and I think he implied he did it on his C36 when he owned that). He said that if installed properly it would be fine. Yes it'll cost some money, but if you really want it, it would only be a fraction of the cost of what a new boat is.As far as other boat builders I do think the Dufour is a nicely built boat just not necessarily right for me. But I wouldn't compare a Bavaria to a Catalina . I won't go into it here, but they are not what you might think they are. But even then both those boats scrimp on price when it comes to keel material. Instead of using the superior antimony lead keel , they use the cheaper cast iron keel. Jack Hornor, the person that wrote that article did an admiral job for the space and time allotted. It was really a very general article on the C36. All too often when people write these articles that have to glean information they best they can and really miss information or very salient points that can take way too much time to research. I can guarantee you that much of the information he wrote was from our website. If you really want to find out how a Catalina is built "now a days" I would go to the Catalina Yachts website. They have an article "white paper" that you can order (or maybe see on the website) that's titled "The Art and Science of Building a Catalina". It is VERY thorough and goes into depth on all the concerns it seems like you might have. After reading this article and seeing the pictures, I think your eyes will be open & will be much more impressed than you would have thought. Persoanlly I think they Catalina's are moving out of being "Chevy's" to "Honda's"
