Dave
I would like to do two upgrades on my 1989/1990 Catalina 34. The first is to add Adler Barbour Refrigeration and the second is to upgrade my battery bank to support it.I've ordered the standard vertical Cold Machine and should receive it in the next week. I'm planning on mounting the compressor in the aft lazzerett and need advice on mounting the evaporator and running the refrigerant lines. Where should the evaporator and thermostat be mounted (top, bottom, etc?). Where should the refrigerant lines exit the box and how do I route them to the aft lazzerett? Regarding batteries, I would like to put four T105 6 volt batteries in the existing battery box for my house bank. Has any one done this? Did they fit and how did you secure them? I'm planning on adding a second battery for engine starting only and am looking for suggestions for a good location, etc.All suggestions and advice are welcomed and I thank you in advance.Dave EmeryC-34 988
