C 30 starting button
David Butke
Sometimes the starting button does not engage the engine and I have to push it several times to get any activity. This is on a 1990 C 30 with the M 18 engine. Does the button assembly have to be replaced or is there any other way to insure the engine will start.
Tom
Try rewiring the engine harness
Your problem may be corrosion in the wiring harness plugs for the engine. If you havent upgraded the wiring harness, contact Seaward products for an upgrade kit. I think the kit cost about 30 dollars. It takes a few hours to install and is well worth the effort.
dave
A couple of thoughts
I don't think you have to upgrade the wiring harness, because I think the 1990 model already has it, but if not, you should look. I think the C-30 association has links to it or catalinadirect.com. I have the same problem too sometimes, and I have the upgraded harness. It usually happens after I've been sailing for a while with the engine off and have to start it again within an couple of hours. I'll charge the glow plugs for about 10 seconds and when I push the starter-nothing. At first I thought it was a battery issue, but I'm not so sure, because I've got enough voltage. Also remember, that in warm weather 10-15 seconds should be plenty of time to hold the plugs. You will have to do it longer in cold weather. A thought I've had: the engine is still very warm when I try and start it, so I think I'm holding the glow plugs down too long. I'm going to try it for 3 seconds or so, when the engine is still warm. Also, I have better results when I open the throttle quite a bit, so when the engine does start, its at 1500 rpm, rather than 900. I never have this problem at the dock when the engine is cold, it always starts. I've asked the same question as you before, but I've never got a good answer other than 'replace the harness'.
John Mavrovich
Harness Upgrade
My '91 was a candidate for a harness upgrade. Basically it's the connector plug behind the cockpit control panel that is faulty. Good luck.
