Which T-track are you referring to? If it's the inboard genoa deck tracks, the gentle curve would be achieved on installation rather than with a built-in track curve.
You simply work from one end, a hole at a time. My technique is to drill slightly undersized pilot holes, then run a thread tap through the deck slowly, chucked in a second cordless drill. Then run down your fastener only moderately tight as it grips on the inner and outer laminates - no washer/nut needed inside at this point. With the first two bolts installed from the deck you can have an assistant bend the far end until the next hole is where you want it, then again drill and tap through the track hole, and repeat, etc. I then remove fasteners one-at-a-time, then re-install each after coating the bolt's mid-to-upper section with Life Caulk (not silicone).
Pete
