Bill Gregory
The bottom portion of the starboardcabin bulkhead in my C-30 TR is rotting at the bottom due to leakage (probably from the chainplate fitting.) I am going to solve the leak but also want to replace the bulkhead. I am planning on removing the bulkhead while the boat is in the water and then cutting new 1/2" teak faced marine plywood to the same size. Are there any problems that I need to know about? BILL
