Problem - The winch for my keel cable is centered not directly above the tube the cable travels through to the keel. This forces the cable to one end of the winch spool, causing the cable to overlap on the spool until it slips towards the center of the spool. I bought the boat used. The previous owner said he replaced the winch earlier in the year because the breaking mechanism did not work. The winch seems to be lined up with the right bolt holes but I can't imagine that it was designed not to line up directly over the cable tube.Has anyone dealt with this issue?Thanks.
