O'Day 22 or 222 is an excellent boat
Hi Ronda,Last year I bought an O'Day 222 which is the 22 foot O'Day that was built the last two years of production (1985 and 1986). It has been a great first boat, and I have no regrets. It is a pleasure to sail and is adaptable to a wide range of sailing areas and conditions (small inland lakes, Great Lakes). The centerboard version draws less than 2 feet with the centerboard up. The only problem I have encountered is a little bit of gelcoat problem on the top side. Specifically, there are several places where I have encountered popouts of the gelcoat. If you are not familiar with the problem, that is where the outermost thin layer of fiberglass coating separates from the skin coat (inner layers of fiberglass). These popouts are about the size of a dime. The problem can be fixed without too much difficulty and there are a lot of nice articles on the web as to how to do this (check out www.sailnet.com's library of articles for examples). I strongly suggest that you get a roller furling jib, if it doesn't come with one. This makes single-handing the boat a breeze. The one on my boat is somewhat lightweight, and although it works well when I sail with a full jib, it's not heavy duty enough to effectively reduce the size of the jib in heavier winds. I will probably invest in a heavier duty model in the next year or so.I have also noticed that the boat points very nicely into the wind. With 800 lb's of lead in the keel, and the centerboard down, it maintains course very well. It is light enough that it also trailers easily with a 6 cyl. SUV or van. The total boat and trailer is about 3000 lb's. For a family of four (two kids under 12), we have camped comfortably on it. You can sail (not camp) with four adults and 3-4 kids without getting in each other's way.Finally, I should note that this boat was very reasonably priced. I found the boat, trailer (single axle, no brakes), and an older motor for $3900. There are a lot of 22 foot boats out there for $5k or lower. I agree with others that there are other boats (other than O'Day) that you should consider, but should you settle on an O'Day, I'm sure you will be happy. Good luck and happy sailing.
