buying an outboard
mikek
I am considering buying a tohatsu 8 or 9.8 hp outboard from porta-bote though the internet. anyone have experience with a tohatsu motor or do business with porta-bote??
G
gene
I like my 3.5 tohatsu
for what that's worth. If you are only lake sailing a 6 to 8 h.p. would be plenty. If you have to deal with currents or such maybe the larger would be better. my thoughts. gene
Jul 17, 2006
75
Oday 302 Port Henry
yamaha
Last month I retired my 8hp mercury and put a new 4hp 4stroke yamaha on my 22 oday. The four hours pushes the boat to hull speed at just over half throttel, runs great and is very economical. My big deciding factor was weight. The 4hp was as much as I wanted to lift. Larry
David
Tohatsu 6
I bought a 2006 Tohatsu 6hp this spring 25 in shaft, battery "charger" is standard 20hrs use so far Starts easily, runs great With no wind will push ODAY 272 to 6mph
K
ken
Tohatsu
Mike, I have a Nissan 8 (made by Tohatsu) on my O'Day 25.... had it for 3 years... runs great and I have no complaints except for the fact that their service/dealer network is somewhat limited. Just make sure you buy the 20" long shaft at minimum.... cause you won't be happy with the short shaft. Good luck!!
W
Warren
Outboard Power
There are alot of good outboards out there, both two and four stroke. Check parts availability.....its real important.
