In the house bank of my Hunter 33 (2007) I have two 110 amp hrs 12 batteries in parallel (220 AH in total) . I believe the max charging rate in amps should be 20% of the total AH rating - so 44 amps. My alternator is 60 amps - so far so good.
I'm thinking of getting a generator. I'm told that the Honda 1.6KW unit (the Honda 2000) is the best. 1.6KW at 12 volts is 133 amps or 133 x 0.70 = 93 amps assuming 70% efficiency of the H33's battery charger. This seems like gross overkill!
So instead I'm looking at a Generac 800 watt generator. At 12 volts it should output 67 amps, or 67 x 0.7 = 46 amps if I allow for 70% efficiency of the H33 battery charger. This seems to be about right!
I realize Honda have the best reputation , but a Honda 1.6 KW (Honda 2000) costs $1350. A Honda 900W (Honda 1000) costs $1099. Vs. the Generac 800W costing $319.
So it looks like a no-brainer! Anybody see a fault in this thinking? Or have other experience or opinion? Anybody got actual experience with Generac?
