Archives and Reviews
Check the archives and reviews for the h25, and all the Cherubini designed Hunters of that era. There is a wealth of info there.Actually, though, the issues are common to all plastic boats of that vintage:1, 2, & 3. Water damage! After 15 to 20 years, most of these boats have some kind of rot of the laminated deck's wooden core, either under the mast, or at other deck fittings, especially the lifeline stanchions. The grid, motor mounts, and lower parts of the woodwork may also have problems.4. Wear and fatigue. Standing and running rigging and fittings can be ready to yield especially if the boat has been in salt water. Plastic fittings for hatches, ports, and plumbing may also be ready to go.5. Corrosion. This is a real issue for salt water boats. That's why they often price around 10-15 percent less than a fresh water boat.6. Instruments. The speedo and depth guage on our '77 h27 seemed to be working, but the digital readout was shot, and the speedo wiring was hopelessly messed up with no docs from the PO.Luckily, all of the above are easy to fix. Make sure that _you_ pick a good surveyor based on recommendations from local boaters, and you can get the seller to pay for 90 percent of the issues.Good luck, the h25 is a great boat!DavidLady Lillie
