I've looked at a couple Beneteau 38' (2001 and 2000). A good friend and accomplished sailer had a 44 CC and wrote: "The hull integrity is fine and they sail well, the problem comes with the systems, particularly wiring and plumbing. They do not use marine grade connectors, wire etc. Pay attention to the fuel and water fill points, they are AL on AL and tend to gall if not treated with tefgel. Also the vent line on the fuel tank was way too small resulting in long fuel times."
On the 2001 I found many hairline cracks on the foredeck, smooth and non-skid areas. Boat came from CA to FL; current owner since 2004 said it was that way when he purcahsed the boat (used).
Any comments, perspectives on the above??
Thanks
Roger
Thanks
Roger
