We have replaced two alternators on our Catalina 380, which is equipped with two 4D commercial batteries and a 2000 watt inverter. We sail once week and the batteries are fully recharged on shorepower 24/7. Our weekend activities include brewing blue mountain coffee and grilling Cuban sandwiches while under sail. Both electric appliances are rated 1500 Watts and used alternately. Our rule of maximum connected load of 1500 Watts is used to protect the inverter. The alternator failure occurs when we fire the engine after using these appliances. Apparently, the battery banks have discharged to the point where the alternator cannot recharge them without toasting its diodes.
This seems crazy, because the regulator should protect the alternator output. Since the battery bank is new and fully charged, what is causing our alternator failures?
Our solution is to run the engine while using the galley.
Do you have a better solution?
Thank You,
JimBerg
Thank You,
JimBerg
