Bulb replacement
An 85 Mac may not have the original mast light. Reguardless of the brand of fixture, replace it by using the current bulb, it should have a number stamped on the metal base. If there is no number, you can go to an auto supply store and show them the bulb and ask them for a replacement bulb for a "side marker light" for a truck. It will be of sufficient wattage to meet USCG (two mile visability) requirements. Even better, once the auto supply store identifies the bulb and gives you a number, go to a motorcycle shop and buy a heavy duty motorcycle bulb to replace it. They are more shock and corrosion resistant than auto bulbs and will last longer.Happy sailing,Mike
