Burlington Press Article / Dan
Dan, I suggest that you go back and read the article again. Your statement of "operator error waslikely the cause of the accident not the boat design," is only part of it. The boat was definately overloaded with people, and the Skipper was drunk, to the point, its a wonder hehad'nt passed out.I'm sure as to what I'm about to say will bring on a string of debates, but we all have our opinions. I hope that the bulk will be more from fact, rather than heresay. The statement regarding reading operators manual and your recommendation for keeping ballast tanks full, is commendable. However the statement of finding the boat unstable over 10 mph with ballast tank empty and mast up, is a little hard for me to believe. I have followed the manual, and also additional instructions from the dealer, from whom I purchased my 26X.I have not had a problem with stability under power with ballast tank empty as you have stated. I've also cruised right along at 18MPH, with no problem, with 2 foot waves. Bounces around, true, but any rougher than that, and the ballast tank is filled. That smooths things out, but I also reduce speed too. With sails up tank full and keel down, I find it sails just fine. Not as fast as a lot of folks might like that own the boats like mine, or folks with other makes, but fast enough for my liking. I will point out that there are other boat manufacturers that build boats with water ballast also. You might check them out. I believe that Hunter has them too. I've owned other boats having full keels, shoal keels, wing keels, and drop keels. They have a tendency to rock and roll, but that is because the hulls are designed differently. In the right conditions, they can give yoou the feeling of unstable too. Power boats, I might add, also ride differently. Again, hull design, of which there are many. I do my boating in the Puget Sound, Straits of Juan de Fuca, where the water can change real fast, as well as the tides & surges, and have been out in the boats I've mentioned. You soon learn how each boat performs. Of all those boats, I haven't found that the Mac26X Is any worse, than other boats. It has been stated, by other individuals that the 26X being a power/sailer does neither well. It depends on the individual and what fits their needs. By the way, all boat manufacturers promote boat and water safety. If the Mac 26X were that bad, MacGregor Corporation would'nt have sold as many as they have, nor would they have a waiting list. I personally have nothing against any other make of boat. Its my preference, and I've been around boats all my life. You did'nt come right out and say if you own a 26X, but if you do, you have let it intimidate you. If you haven't sailed that long, and are just learning, get instructions. Just remember, that even though you either receive instructions, or have sailed for awhile, you will learn more each time out on the water. If you don't own a Mac 26X, than I suggest you should do a lot more research on them before making statements, that someone can and will prove you incorrect.
