Bunks or Rollers
Ric Trimmer
Okay, here's a trailer question. I have an E-Z loader trailer for my O-23. It is equipped with rollers for the keel, and two sets of rollers on each side to support the hull. These are on posts about 2 foot high. This is the total support provided by the trailer. I have seen pictures of other 23's on trailers that have the extended bunk boards on the sides, rather than the rollers. Is there an advantage/disadvantage to either design? I am considering trailering my craft from Michigan to Florida over the Christmas holidays to get a few days of sailing in December. Is my trailer configuration up to the task of the long haul? I'm in the process of overhauling the trailer before the boat comes out in October. This is the time to make any changes that may be needed. Any advice would be gladly received! Thank you, Ric Trimmer s/v Whisperin' Wind O-23 Lake St. Clare, MI
Brad
Just my thoughts....
Ahoy Ric, if you have a fixed keel, that's where most of the weight of the boat ought to be resting. The rollers on the sides should be supporting little weight and should be really just serving to keep the boat from falling off the keel. in this situation, I'd stay with the rollers. If the boat were not a keel,and the full boat was resting on those supports then I'd say that the bunks would be better as they would afford less weight per square inch against the hull. Good Sailing, Brad on the Willy T
