Bunk Size on 42
I have a 1990 three cabin model and the owner's bunk is th same as for the MKII, You will find that it takes a queen size sheet at the top of the bunk and a little less than a standard at the bottom. Our is the three cabin model and the port and starboard aft cabins are slightly smaller, but we use the sam sheets, queen size at the top and standard at the bottom. Length of all is constant at about 75".I think that the factory could give you exact measurements if you need more. Call them at 818-704-6612.Regards,Bob TeeterCamelot 215
