OK.. best bet seems to just rebuild and forget the outboard..
Next question.. has anybody removed a YSE12 from a hunter 30?
If so, how did you get the motor out the cabin door (will it fit).
Since the boat is in the slip and I cant get any type of lift over the boat,
I am wondering how to manuever the motor out of the boat.
Anybody have an idea what a YSE12 Weighs?
thanks
I needed to rebuild my YSM12 last winter. I opted to take only the engine and leave the reverse gear housing and rear mounts, shaft and coupling in place. I unbloted the crankcase off the front mounts, unattached all the lines, wires and hoses, and detached the clutch housing. I opened the shifter housing and removed the shifing collar. Using the boom and a boom vang for a tackle and attached to the motor I physically rocked and twisted the engine through the opening and onto the salon deck. I'd guess the weight at 200-225 lbs without the clutch housing. I had a local commercial dock hoist the engine out of the boat into my trunk for me for a six pack.
After the overhaul this spring I lowered the engine at the commercial dock into the cabin. I used a small roller jack and the boom and vang and wrestleld, pushed and twisted the motor back through the opening. The roller jack was critical to aligning the clutch with the housing and getting the engine up once inside the "hole". I removed the altenator, water pump, alternator brackets, fuel pump before attempting this. I also had to turn the starboard forward mount so the waterpump mount wound not be in the way.
This method is crude, potentially dangerous to the woodwork and if not done with a boatload of luck a bad outcome is possible. I worked alone and spent about eight hours on removal and installation with the boat in the water.
I would guess a boatyard would have to haul the boat and put two men on it for a day to take apart the interior and remove the complete engine. There would be crane truck charges too. I figure the total overhaul cost me around $3K. Just about what a good boatyard would charge just to haul the boat take the engine out and put it back in and relaunch.
The engine had been in the boat for 31 years and the only appreciable wear was the conrod bearing. Piston, liner, crank, all within serviciable limits. We were amazed with the good condition of the internal surfaces after all that salt water!
Bottom line is you can do it, just go easy and be careful.
