Tim
I have a 1971 Ericson 29 and I want to do some work in the cabin. Part of this involves installing 2 new bulkheads that will surround a new and larger head.The bulkheads will be made out of 3/4 inch marine plywood glassed to the hull. Will also paint with a good quality paint.My question is this. In Don Casey's book This Old Boat he recommends putting a foam pad between the bulkhead and the hull to prevent the joint from causing a hard spot. Is this necessary? I would have thought it would be best to glass the wood directly to the hull for a stronger bond and to help stiffen the hull.Thoughts?
