Kittywake has been a lawn ornament for a little while now, so I am starting to get to a little bit of restoration. I just reconstructed the "false" bulkhead on the port side that separates the galley from the cocpit locker. The old one had pretty well rotted away, as a "fix" a previous owner had put white plastic on the bulkhead. This plastic and a small bit of the bulkhead remained I was able to use it for a template. I cut a piece out of ridged insulation material for a test fit. When everthing looked good I transfered the shape to plywood (1/2 marine grade ply bonded to 1/4 okume with epoxy). I cut the piece out then test fit the plwood bulkhead which needed a little shaving here and there. I coated the bulkhead in epoxy and varnished the finish side. Today I plan to epoxy the other side (locker side) and paint that side white. I call this a false bulkhead because it is not tabbed in, and originally it seems, was was just screwed to the cockpit framing. I plan to epoxy some small teak cleats to the hull so that the bottom of he bulkhead may be more securely attatched.
I will post pictures later.
Jimmy Small
949L
Jimmy Small
949L
