John Richard
Sorry for this long diatribe, but have any of you heard of the following quirks?We took delivery in San Diego on our new (serial number 41304) 410 this past Tuesday. The wind was calm in the marina and the temperature was warm. After motoring out into the main channel, the main and jib were raised and the boat started to show its stuff. After clearing Point Loma, the breeze freshened to over 20 knots and I was in heaven. We went out toward a couple of entrance bouys and gybed back and assumed a port tack. After a short while, I heard two noticeably (loud) cracks. I saw our delivery skipper and my salesman go below and huddle near the nav station. I was too engrossed to have enough sense to find out what was going on when they came up and said that they were going to lower sail and motor in the rest of the way. The wind was still blowing and furling the main took some effort. The jib also rolled up too tight and there wasn't enough line left to allow two wraps around the head stay. After we docked, (backing; I did it perfectly) they showed me that the bulkhead had separated from the hull behind the nav station seat. They examined the port chainplate and could not detect anything out of the normal. After getting the head service guy in, and a call to Hunter, it was decided that this particular bulkhead may have been configured too close to its tolerances, and when the wind put the boat into a 18 plus/minus heel, the thing separated. You can see the caulking in the shower gave way. We decided that the boat was sound and the next day I brought her up the coast to Newport Beach during a very wet, cold and foggy night sail. Except for a wonderful school of porpoise, and having to divert around a research vessel off La Jolla, the trip was uneventful. I love our boat. Have any of you experienced or heard of this bulkhead problem. Hunter is going to make repairs. I just remembered. The sink in the aft head won't drain. I was told that 410's have a design problem and the drain pipe is situated that the water takes forever to go down to the holding tank. A solution is still on the drawing boards.John Richards/v Jack's Place
