John Owen
Both my port and starboard bulkheads have rotted at the bottom. Since the bulkheads are structural (they reinforce the hull shape and serve as the mounting point for the chainplates), this creates problems in heavier air and seas.Although not easy, I was able to remove the port side bulhead and have done a nice job with a jigsaw of making a replacement and staining it to match the original.However, I cannot for the life of me, figure out how to remove the starboard side bulkhead for replacement. It appears that one must actually remove the deck (which ain't happ'nin', I can assure you) to accomplish the task. The only way I can see that it could have been originally installed is with the deck off. Any suggestions for the starboard side? Is there a trick to can tell me? Is there a reasonable work-around?Thanks.J.
