Bulkhead Formica
WoodyB
Mar 10, 2014
20
Hunter 1989 30' St. Andrews, NB
When cleaning up my new Hunter 30, I discovered that some water had been trapped between the aft mattress and the aft bulkhead. I dried the area but the formica coating on the bulkhead chipped away. I found the same issue in the head.
There is no rot, but I want to cover the exposed area. I am looking for suggestions. Should I paint the area or seal it with epoxy etc.?
Woody
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
Woody
anything you do short of replacing it will look like a patch job.....but you can make winscote type repair where you put a thin sheet over the damaged area with a horizontal line on the surface aqnd then cap it with some teak trim ......
regards
woody
