Tom H
Doing lots of interior work on an Irwin 31 with a teak ply interior. The main bulhhead has compressed in enough that the door will not close, almost half an inch of wood will need to be removed to trim the door. Coincidentily (or not) the keel to hull seam has opened about 3/8 of an inch. The keel bolts are fine and torked correctly. Do these hulls tend to compress as the keels pull down over time? The boat is only in the water 6 months a year. We replaced the entire sole bds (floor) do to rot from mast, bilge etc.
