compass bracket
We have a 25 and the compass is on a bracket I have been on larger boats and they were on brackets also. I have always liked the security of being able to remove it when we leave and its kept out of the weather (I wonder if it can freeze??). In a public marina down from us there was some vandalism and some compasses were shattered and others stolen. I figure "out of sight out of mind". With the bracket you dont have to worry about the angle either. If you do decide to drill a big hole use a hole saw and apply masking tape to exposed surfaces being drilled through, this helps prevent splintering and scuffing if you goof. Drill from the outside in to the inside, the side you start on usually looks better. Make sure you dont lay into it or when you break through youll smash the drill into the side of the boat and splinter the other side. Decide which angle the hole should be and keep it that way either paralell with the deck or perpendicular with the surface to be cut if you make the wrong cut youll have to widen the top of the hole and have a gap at the bottom depending on the thickness, Rember to wear a dust mask and clean up, fiberglass dust is as bad as asbestos. I havent drilled or cut into a boat yet but I have installed equipment and found these a few things to remember...hope this helps...Marcie
