built in exhaust tank on 1984 31ft Hunter leaks
25
Hunter 31 Sea Isle City
I have a 1984 Hunter 31 and all season my bilge would fill up with black/raw water. I finally found the problem, my built in fiberglassed exhaust has a leak, probably from age. Is there a solution to this, or should I just cut it out and replace with a new plastic tank exhaust? Thanks so much, OceanDriver.
Dec 2, 1999
15,184
I think the exhaust box is just fiberglass. I would suggest that you consider a FG patch. That should take care of the problem.
PS: Where is the hole?
Oct 30, 2011
542
klidescope 30t norfolk
you must be getting some exhaust fumes in the cabin as well replace it for piece of mind there only $150 new at defender .com
May 24, 2004
470
Hunter 33.5 Portsmouth, RI
They are usually Vennalift Mufflers. You can Google Vernalift Mufflers and get their Web Site. They will have a list of the P/N's for all of the various dimensions of the muffler. From that you can determine which is yours, and if there ia a new P/N that replaces a discontinued one. I found mine on their list for my 1990 H-33.5. It had a new P/N. I haven't replaced mine, but I captured the right P/N for it.
Dec 2, 1999
15,184
The muffler on the H'31 was NOT a traditional unit. If Ocean Driver decides to replace the built in box with a traditional water muffler he will need to cut the box out and find a place to install a new thru hull for the exhaust hose connection and build a new platform for his fuel tank.
Not a lot of money if he can do it himself, but a lot of work.
