Bug Screens
Matt: I always get eaten alive too. I figure that the bugs just like Italian food.Anyhow, I put velcro around the front hatch, (on the underside looking up). (Put the part of the velcro without the hooks here). Then I took a screen and sewed nylon strips, about 2 inches wide, around it and then sewed velcro onto the nylon to correspond to the velcro frame around the front hatch. This screen goes up and pulls off of the velcro easily and quickly. I used a screen cloth that was for "no see ums", but I can usually see the mosquitoes that are biting me. I actually want to make another one with bigger holes to try to get a little better airflow through the front hatch.For the main hatchway, I have a strip of velcro on the inside of the top sliding hatch. Then I use the snaps that are on the outside of the wood to snap a screen over the main hatchway, 3 snaps on each side. I pulled a strip of foam into the nylon trim strips to get a better seal between the nylon "frame" and the wood that frames the hatchway. The screen for the pop-top is still under development, or what Ken called a hurry project. We just bought a sleeping bag screen and throw it over the pop top and clothespin it in place. The plan is to sew a nylon cloth trim frame for this too, and put a piece of flexible fat rope into it to weigh it down to seal against the cabin top. I will probably put a slit in it so that it goes around the mast a little better too, if I ever get around to it. It works fine the way that it is, but it could look neater, and be quicker to set-up, if the nylon and rope trim was installed.One good thing about all these screens is that they don't take up much space or weigh anything. We use them most of the time, and we sleep on our boat every weekend all summer. I recommend that you at least buy some screen before you go on your first overnight adventure. You can always just place it over the hatches and hold it in place with extra docklines and clothespins.Aldo
