Does it make sense that my Yanmar 2QM15 would get tiny bubbles in the fuel that would prevent me from bleeding it and re-priming it? I ran the motor with the priming pump valve at the top of my racor fuel filter un-screwed down which probably let air into the fuel causing the motor to die. I did this once before and was able to bleed and reprime, but yesterday when I tried to bleed it there were many little bubbles in the fuel, unlike before. Sorry if I'm using the wrong words or not explaining myself well. Do I have to just let it sit and then bleed it again?
