Doug
I'm looking for some advise on a recently discovered problem with my H23. This is the second season I have owned this 1985 boat. I sail on lake Erie out of Cleveland, and keep her on dry dock during the winter. Before I put her in the yr, I sanded and painted the entire hull w/Interlux antifouling paint. After launching a few weeks ago, I noticed a very slow leak from the 2 small plugs under the foward floorboard in the main cabin under the mast and table area. When I pulled the plugs, about 1.5 inches of dirty brown water poured in (Please, no Cleveland jokes here, the water in the marina is NOT brown). After cleaning this up, about 1 week later it reappeared, this time water also filled in about 1 inch under the aft floorboard. No water under the middle board though. Is this a problem with water leaking in around the hull/keel joint, since I did not re-caulk after sanding? Could this water be leaking in from the side rub rail (which is missing some caulk) or the mast boot?. Or is this a problem with leaking keel bolts? By the way, how many keel bolts are there in a H23, and what is the purpose for those 2 small plugs I previously mentioned. I should mention the boat did not leak last season and ever since the boat has been in the water this year it has rained a significant ammount. Thanks
