Bronze Screws
75
Hunter 31_83-87 Key West
I've found most of the interior is held together with bronze screws, the heads of which stip-out 70 percent of the time. Does anyone know why bronze screws were used in these areas, and if they're really necessary or can be replaced with screws of a harder metal. Scott Fraser Rubicon Key West
Steve O.
stainless
The bronze color matches better with the wood interior, but you could replace them with SS if you want to pay more.
Jun 2, 2004
87
Hunter 33_77-83 Montevallo Al
A technique that helps a lot in getting a silicon bronze screw out is to first make sure you have the right size phillips head, and second, give the screwdriver a good firm tap with a hammer to seat it before trying to unscrew. The tapping may have to be repeated before the screw is removed.
