Jim Torap
This is a Hunter 40.5 and the steamer light is about20' up. When I pulled the light off for repair 6" of broken cable came with it. There is enough slack in the cable under the mast were it goes into a pvc pipe(caulked) but I can't see how the wire was run,or supported and fed out the 1/2" hole. Looks like they built the mast around the wire. Please Help THANKS
