Guess this will teach me to worry about dock lines. Had the boat (1983 Hunter 31) out Saturday, motoring the local area, when the engine vibration and noise below the cockpit suddenly increased dramatically. No obvious impact with anything, no impact noise, 20 feet of water under the keel. After checking a few things aboard (no mask or fins on boat, major learning lesson), I decided to limp home under drastically reduced throttle with what I thought was a bent or out of balance prop blade.
Put a diver on the boat today for cleaning and he reports a broken strut. Fun first two weeks!
My questions for the panel:
1) Any recommendations on yards in the St. Petersburg area?
2) Anything special to watch out for during a repair like this?
3) Does anyone know if the shaft will come out without removing the rudder? (Not that removing the rudder will add significantly to the cost, but it is one more thing to screw up in the yard.)
I have decided to look on the bright side - the boat needs a bottom job, and now the haulout is free.
