broken filler cap for yanmar 3ym20 transmission
May 1, 2021
26
C&C 33-2 Sidney BC
Has anyone had to remove a broken plastic filler cap/dipstick from a transmission. The cap completely failed while being hand tighten, the head coming out but
leaving the threaded portion screwed into the transmission. This is plastic so I suspect fragments would remain in the transmission if I tried to tap it out with screwdriver.
thanks
Dale
Jan 7, 2011
5,807
Oday 322 East Chicago, IN
Quite a few threads on this problem…
search Yanmar Transmission dipstick
Likes: tfox2069
May 1, 2021
26
C&C 33-2 Sidney BC
Not surprising, I can't be the only one to have this happen and yes it is only about 5 deg C.
Jun 21, 2004
3,038
Beneteau 343 Slidell, LA
Try cutting a slot across the broken surface, deep enough to engage a flat blade screwdriver to allow the cap to be unscrewed. If you want a permanent fix, order a replacement from Caribluemarine.com
Likes: tfox2069
