C
Chris Baker
Having just returned from a wonderful sail in the San Francisco Bay where the wind in the 'slot' between the Golden Gate Bridge and Berkeley was letting us surf on the waves and cream past 40 foot yachts, I arrived back to find that the centerboard cable came away in my hands as I tried to pull up the board. I had not reversed with the centerboard down (though I have done this mildly before at the end of a shallower than expected launch ramp). So the questions are:1. How is it possible for a cable with a breaking strain of probably 2 tons to break? (I am assuming that it is a matter of kinking and flexing rather than straight pulling). How can one stop this happening again?2. How can I fix the cable? The centerbord pivot appears to be fine, so I am assuming the only cheap way is to launch (with a strap around the center of the boat to prevent the board digging in as one reverses thge boat off thre trailer) and then fix the cable under water. Presumably the cable attachment is similar to the attachment at the rudder - a bolt through the trailing edge of the centerboard with an eye in the cable? Is it shallow enough to use a breathing tube to the surface?3. By the way I have sometimes found the centerboard sluggish to go down (perhaps, now I have had this failure, because of cable kinking). Is it possible to add more weight (lead?). Also at speeds of 6+knots I imagine that the drag pulls the centerboard back creating less effective centerboard area and hence more leeway?Would like to hear from any of you who have thoughts on this.
