I have a 5/16" - 18 SS bolt that threads into the bottom of a SS stanchion that was frozen. I got it started and turned out maybe an 1/8" before I broke the head off during removal, leaving approximately 1/4" of the bolt shaft protruding after removing the stanchion from the boat.
I figure there's another 1/2" worth of bolt still threaded into the stanchion.
I've been applying liquid wrench and rapping the bolt with a centre punch/hammer occasionally. I intend to put a torch to it before attempting complete removal.
My question is...
...which would you attempt first (most likely to succeed)?
-cut a slot and turn out with a large slotted screwdriver?
-clamp vise grips on as tightly as possible and turn out?
-drill a hole for an easy out and turn out?
Thanks!
My question is...
Thanks!
