Randy K
Thought I'd pass on my story as it might be of some help to others. When I brought our 1986 C-22 I noted that it had a crack in the back of the rudder. Over the winter I "repaired" it with MarineTex. It seemed fine so far this season. Well last night sailing against a strong wind the rudder snapped in two just below the lower pintle. After a wild couple of minutes lowering the sails and getting the ob going we managed to pick up the 3' piece of rudder (it was floating) and motor on back to the slip. Ordered a new one from Catalina Direct today. They told me the new ones are foam inside since the wood ones kept getting wet and rotten. No kidding! Anyway if you suspect your rudder has gotten water inside be careful. Randy
