Apparent Wind and Leeway
Jean,My interpretation of what you experienced is the effect of "apparent wind." As your boat speed increased in the stronger winds, it caused the wind over the boat to move forward, causing the boat to heel and making you overpowered on a beam reach. Having the centerboard down didn't cause it but did act to make the boat dig in, resisting the sideways motion of the boat and further increasing the heel. Pulling the centerboard up allowed the boat to make leeway by sliding through the water sideways, reducing the heeling effect and lessening the weather helm you experienced.The way to counteract this tendency is to depower the sails, either by letting out the main sheet or reefing the main in the winds of 15-20 knots. If you were not reefed, you were definitely overpowered in such winds. The centerboard should be down on anything but a run to help hold the boat on course. If you'd looked behind you as the boat sailed with the board up, you would probably have seen your wake arcing away from your intended course though the bow would still be pointed toward your destination. You may have been going faster but in the wrong direction! Leeway is the tendency of the boat to be blown sideways from the force of the wind and the keel or centerboard is the vertical wing in the water that helps you hold the course.HTH,Dick VanceH-25.5 "Honey Bear"
