Broaching is where your mast runs into the water.Normally, this is only an issue with very high winds and sea, conditions that most likely you would avoid.As a general concept, the sails fill with so much wind, they literally knock the vessel over onto its side and therefore the mast goes into the water. The problem becomes whether the boat will right itself or not.Assuming you ease the sheets, and the cause for the broach, such as a sudden wind gust or a rouge wave, has dissipated, the vessel should right itself.However, if the wind continues strongly against the side of the vessel, seas continue to pound her, water starts to enter through the companionway, and you eased the sheets, assuming your rigging is still intact and not a pile of junk all over the deck, well, that’s that.Nevertheless, to avoid a broach, one must instantly ease the sheets. As far as the Catalina 25 is concerned, I think you’ll agree the factory mainsheet set up and factory horns or cam cleats for the jib sheets are poor.For the jib sheets, I would replace either the horns or factory cam cleats with Ronstan cam cleats that should release more easily.For the mainsheet, you’ll need to move the end of the sheet and its cam cleat to either a barney post or similar to the fashion I have on my Catalina 22 that for practical purposes is very similar to your Catalina 25. You can see my main sheet set up at:http://tinyurl.com/88t92
