Bristol Corinthian engine well plug
Oct 20, 2021
4
Bristol Corinthian 19 Penobscot Bay
I just purchased a 1970 BC. It has an engine, but I don't want to sail with it in the well. It does not have a well plug. I understand the plug would have been fiberglass? Any idea where I can find one?
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Welcome to the forum and congratulations on your new sailboat!!
Can you please post a photo of the engine well you wan to plug, where is it located and function?
Oct 20, 2021
4
I will look for a picture online. The boat has a through-the-hull motor mount. The motor is a Honda 2 HP air cooled four stroke. it sits to the port side of the tiller, in the port half of the seat which would otherwise go across the cockpit under the tiller. The ones I have sailed on in the past do not sail with the motor attached. Without the motor there, there is a hole(about 12" x 12") that looks directly into the water. So a plug goes in the hole (usually of fiberglass, maybe always of fiberglass), that fits in and has a pin that holds it in place. So the cockpit seat goes all the way across--with a slight lip where the plug is. I have a sense it was original equipment, but am not sure.
