Bristol 22
Aug 1, 2022
1
bristol 22 Mattapoisett
We just acquired (cheap) what we believe is a Bristol or Sailstar 22 but the vin is not proving ideal to ID the boat. Any thoughts?
My first thought is
THAT IS BEAUTIFUL!
Here is the spec sheet for the bristol 22
Maybe you can compare some of the dimensions and rig specs to confirm. At first glance it seems like a Bristol
May 25, 2012
4,338
sweet vessel, throw it in the water and start having some fun. you got all winter to find out what it is :cool:
Likes: ggrizzard
Jun 9, 2008
1,801
- -- -Bayfield
While I have a lot of old Bristol brochures, I don't have one on a Bristol 22. Looking at the Bristol 24, there are a lot of similarities, but not exactly. Your photo looks like it was taken with a wide angle to it, so there is distortion, I believe. The shear on a Bristol 24 is not as straight as the one in your photo, but like I said, the photo may have distorted the line. The windows on the 24 are not as rounded as your photo, which might suggest that it is not a Bristol. And the 24 has a full keel with an attached rudder, rather than a fin with a spade in your photo. The Bristol Caravel opted above is definitely not what you have. The Bristol Sailstar was not made in a 22-footer and the 19 and 23 had the same long keel with barndoor rudder as the Bristol 24. So, my guess is it is not a Bristol. As far as the hull # is concerned, boats of that vintage didn't have the hull ID number that boats of today have. They usually were defined by the sail number, which often was displayed on the mainsail. Speaking of the mainsail, if it is original, it might have a logo displayed which also could indicate the brand. That riveted on hull ID might be a state assigned hull number too.
