Brightwork sander
2,439
S2 11.0A Anacortes, WA
Bought a Bosch detail sander and started brightwork today. It has several different shapes of heads and is variable speed. Used it where I could not get my DeWalt sander in very well and also in sensitive areas that sanders can damage...This... sander... ROCKS!!!! I bought it cuz it has several head shapes and I have a Bosch jig saw which also rocks....Wish I had it 30 yrs ago. Very little hand sanding..
RichH
Feb 14, 2005
4,773
be very careful with these 'detail' sanders when finish sanding teak. Use them only on the slower speeds or you risk the possibility of burning / darkening the teak surface cells by the high heat generated due to the ultrafast sanding action .... and which is damn hard to further remove as the burn / discoloration can go 'very deep'. Have the T shirt.
