bridge clearance
V
Vern Malin
I'm considering purchasing a Catalina 27 this Spring. Can anyone tell me the mast height, from the water, for the standard and tall rigs. Thanks, Vern
Jun 2, 2004
1,077
Several Catalinas C25/C320 USA
C27
Try the C27 web site: www.catalina27.org If no luck, try Catalina Corp: 818-884-7700
Joe
Jun 1, 2004
8,320
mast height
the "i" dimension.... top of mast to the deck... is 34 feet for standard, 36 feet for tall rig. Add about four feet for deck to water line... that gives you about 38,40 ft....not counting whatever sticks above the mast, such as vhf antenna.
Jon W.
May 18, 2004
401
Catalina 310 C310 Seattle Wa
I dimension
The "I" dimension is measured from the lower forestay attatchement at the bow to the top of the forestay. The measurement from the deck to the top of the mast is the mast length. Not the same thing. For a masthead rig, the "I" dimension is longer than the mast height.
Joe
Jun 1, 2004
8,320
"I" dimension - defined
The "I" measures the height of the foretriangle. Here are a couple of links that explain the P,E,I,J dimensions: http://www.cruisingdirect.com/PEIJ.htm http://dan.pfeiffer.net/boat/ratios.htm#rig The "I" dimension is not measured from the bow. quoted: "I: A dimension from the headsail halyard hoist to the sidestay termination (chainplate) or sheer line of the boat." "mast height" , Jon, is normally used to express the overall height of the masthead above the water surface which is the question I was trying to answer. In my solution, the "I" dimension can be used because the Cat 27 is a masthead rig. So adding the freeboard height to the "I" should give one an approximate mast height.
Jun 2, 2004
1,077
I think the question pertains to bridge clearance...he's not interested in sail measurements, but if the boat will clear a bridge.
Jon W.
May 18, 2004
401
Question?
Bert, then why don't you answer him instead of interpreting his question. And he didn't say anything about a bridge. I know what he's asking, as I imagine everyone does, I was just trying to clarify a definition in a subsequent post. Sorry I’m a little snippy. And as for that definition, I stand corrected. Learn something new every day!
Jun 2, 2004
1,077
First Post
I thought I answered his question in my first post...since he mentioned "bridge clearance" in his subject.
Joe
Jun 1, 2004
8,320
Actually, Bert
You did NOT answer Vern's question specifically. You suggested he go find the answer himself by looking in the websites you mentioned not really knowing if the answer was there or not. That's why I jumped in with my explantion. You obviously didn't understand my post, or Jon's comments or you wouldn't have made the remark about Vern not asking for sail dimensions.
Bob B.
Hey guys, give it a rest!
Is it that important to get the last word in? We are here to help one another. Vern was asking for help & he has the information. It is never wrong to steer a newbie to the correct website for his particular boat. Who cares who said what to whom. Happy New Year to all sailors.
Jan 12, 2006
48
Catalina 25 All Over, USA
Tough!!
I agree with my name sake, Bob B, you guys are tough!! First guy asked a question, second guy answered the question, end of discussion. Vern, go buy that C27, wonderful boats, easy to sail, lots of support from the C27 forum, parts readily available and even factory support if you need it. But, don't buy it unless you can get it under that bridge!
Jon W.
May 18, 2004
401
2nd guy didn't answer
He told him to go ask somewhere else, which is not wrong, but it doesn't mean that it has to be the end of the discussion. And we were at the end of the discussion until Bob just posted. What was that about? Now that wasn't too tough was it? This has been a frustrating thread, because there have been three somewhat critical posts. One implying that discussion of “I” rig dimension wasn’t appropriate? And one telling people to “give it a rest”? And the last one was basically “piling on”. These three posts were comments on poster’s actions, not about sailing. Sorry I took the bait, I usually can ignore these things.
