Bridge Clearance Oday 22
12
2 none none
What's the bridge clearance on an Oday 22. I need to get under a fixed bridge that is 28' 6" at mean low tide.
tks.
Dave.
Jun 2, 2004
1,944
Oday Day Sailer Wareham, MA
Well, that depends on whether you have a 1972-79 model (masthead rig) or a 1980-83 model (fractional rig). The masthead rig has a theoretical bridge clearance of 27'0" but that does not include and radio antenna or wind instruments (Windex, Spar-Fly, etc) or such that may stick up above the mast. The newer fractional rig boats have a theoretical bridge clearance of 31'0" and so will not fit under that bridge.
You might just squeak under that bridge with one of the masthead rig boats if you don't have an antenna, provided the water is flat calm and no stinkpots roar by with a big wake as you pass under the bridge!
