Bridge Clearance at Stuart, Florida
W
wayne
I have a question about bridge clearance over the ICW at Stuart, Florida. I have been told that the bridge clearance from the ICW channel from Lake Okeechobee is 50'. But I have also heard that it is 60'. Does anyone have any recent experience in traversing the ICW from Lake Okeechobee to Stuart?
Jun 2, 2004
87
Hunter 33_77-83 Montevallo Al
Port Mayaca railroad bridge
Clearance is 49 feet with the bridge raised. Indaintown marina has a heeling service which can squeeze you through with a little higher mast. My H33 at 47'3" breezed right through.
W
wayne small
Thanks, Terry
Thanks for confirming that. When was the last time you made that passage?
Jun 2, 2004
87
Okeechobee
I passed through Okeechobee and Port Mayaca twice in April-May 2004. Unbelievable Garden of Eden wildlife on the canal on the western rim. Anchored for a couple of days in this rim canal just north of Moore Haven. The little fellow shown here was there but had a mama that gave us a real scare.
C
chet p
aug 04
i made passage thru the waterway aug 1st 04 just before charlie struck...clearance at the bridge depends on the height of the water in the lake... the day i went thru clearance was 52 feet as the lake was low but after all the hurricanes past the clearance was down to 46' i think the attached link will give you daily heights of the lake and the bridge ( try http://www.saj.usace.army.mil/h2o/reports/r-oke.html ) good luck
